Re: sickle mower parts for Cub or Super A
Posted by mkirsch on July 14, 2014 at 04:45:59 from (65.199.189.6):
In Reply to: sickle mower parts for Cub or Super A posted by crlndy on July 13, 2014 at 08:27:22:
Nobody else has pointed it out but your pictures did not come through. You must post them to one of the gallery pages on this site, or an online photo hosting site, and link them into your posts. You cannot attach them directly.
Yes it does matter Cub or Super A. The mower "head" is the same, but the mule drive, the part that mounts to the tractor, is different enough that they are not compatible, and there is too much different to make a simple modification.
The Cub version is much more common so it is likely you have a Cub version.
The Super A mule drive has a standard right-hand (righty-tighty) thread on the pitman pin on the flywheel. Cub is a left-hand thread. That's the dead giveaway.
The front hanger on the Super A version has an X-brace, and is much taller than the Cub version. The Super A shaft is also several inches longer, but I don't have a measurement on hand.
You are going to find parts the same way you find gold in a river or a penny on the ground. There is no widely advertised reliable source of parts for this kind of thing. Think scrounging.
In fact, you may be better off looking for another complete mower than trying to piecemeal this one together. Then you will have parts and when someone like you comes along asking about the same thing down the line, you can then say, "I can help!"
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
