Re: International 2400a Gas Dies Under Load
Posted by El Toro on July 16, 2014 at 04:15:25 from (96.244.7.206):
In Reply to: International 2400a Gas Dies Under Load posted by BradFr on July 15, 2014 at 19:24:41:
Your engine may be running lean. If that carburetor has a main jet adjusting screw you need to open it. Also check the vanes in your water pump as they may be worn. Touch the bottom radiator hose lightly with your hand to see if that hose is hot. Hal
