Re: International 2400a Gas Dies Under Load
Posted by Ih2400 on July 17, 2014 at 11:04:44 from (166.181.82.23):
In Reply to: Re: International 2400a Gas Dies Under Load posted by El Toro on July 16, 2014 at 04:15:25:
We have the same tractor with the c-175 in it. You probably have the c-157. We also have the same exact issue. In our case it"s a head gasket, and probably a burned exhaust valve from overheating. We also have a cracked manifold, but we replaced that. It warms up, loses compression, and then goes to pieces and barely runs. Not as bad in really cold weather, but in hot weather it doesn"t last long. We also threw all those parts at it that did with no avail. We must have gone to the same auction. I"d suspect the same thing with yours. Good luck.
