Re: 544 Spark Plugs
Posted by Ralls Grove Farms on July 17, 2014 at 15:36:09 from (50.45.28.155):
In Reply to: 544 Spark Plugs posted by mkirsch on July 17, 2014 at 05:13:28:
I was thinking the same thing about going back with the Autolite 45's. I am going to use it this fall to plow @5 ac or so and want to have options if it isn't burning correct so I can go up or down in heat range. It had to be bored 40 oversize and the crank was pretty much shot and no one would touch it but a older gentleman that is retired was called in to a shop to see what he could do with it and I think it is 40 or 60 undersize, cant remember which. He went as far as he could and still get me bearings. Still has some groves in rods but not bad enough to worry me too much so I bumped up the oil pressure a bit. After all it only turns 2200 rpm. Thanks for the help, Kent
