Re: Farmall 656 (Gas) Engine Knock - Need Advice
Posted by pete 23 on July 17, 2014 at 20:12:40 from (74.33.72.212):
In Reply to: Farmall 656 (Gas) Engine Knock - Need Advice posted by DanneboFarm on July 17, 2014 at 13:40:49:
First and easiest place to look is in the oil filter. If you have a rod or main bearing failure you will find shavings of brass looking material in the base when you take filter off. That would indicate major problems. If you find nothing or possibly fine aluminum you may have a scored piston and that, although serious is not as bad. In any case you will need someone with some experience do the repair or at least guide you in doing it.
