Re: may be out thinking the problem,
Posted by ericlb on July 18, 2014 at 06:08:46 from (67.142.161.19):
In Reply to: Re: may be out thinking the problem, posted by clint s on July 18, 2014 at 05:52:12:
checking flow at the end of the hose going into the carb, ill check it at the bottom of the bowl, forgot about that
