Re: may be out thinking the problem,
Posted by clint s on July 18, 2014 at 07:07:45 from (67.242.45.169):
In Reply to: may be out thinking the problem, posted by ericlb on July 18, 2014 at 06:08:46:
If it is partially stuck it will still flow just not enough under load to keep up. I would start with a few gentle taps to the bowl when it was empty, but you probably will have to take it off and clean it. Could be a bit of water in the gas or a partially plugged filter or screen. Will it stay running with no load ???
