Pilot, a Ballast Resistor used on coil ignition systems is more like 1.2 to around 2 ohms NOT 25 ohms. If a 25 ohm were used as a ballast resistor on an ignition system there wouldn't be any spark.
When people used a Delco 10SI type of 3 wire alternator they often used a diode while some such as myself used a 10 or so ohm resistor to prevent ignition feed back and run on. But that was in the EXCITATION circuit from the ignition or coil to the small side No 1 terminal on a 10 SI Delco alternator I HAVE NO IDEA WHAT YOU HAVE OR HOW ITS WIRED.
The big main output on an alternator would NOT go through a 25 ohm ballast resistor, it would go to an ammeter or the dash so it gets to the hot battery post eventually.
I don't know if yours is an excitation circuit resistor (like 3 wire Delco 10 SI used) or what it is but I dont see a 25 ohm ballast in the alternators big main output regardless of what alternator you have.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
