Re: ballast resistor/ IH 184
Posted by pilot199 on July 22, 2014 at 15:28:04 from (184.46.45.90):
In Reply to: Re: ballast resistor/ IH 184 posted by John T on July 22, 2014 at 12:48:04:
Thanks for all the help boys. John T you hit the nail on the head! I got the NAPA ICR13S ballast resistor & it's right on 2 ohms.
I got 'er up & running, charging the batt. at 13.8VDC.
Thanks to all for the input.
Now if any of y'all have experience with the model 3160 belly mower (60" cut) I'd love to hear from you. This thing will kill the engine when flipping the switch for the pto, unless the tractor is driving ahead! Sitting still it will bog the engine down & then kill. Once the mower deck is spinning there's no problem stopping or going ahead.
Is it possible that the battery (which is new) needs to recover from not being charged by the alt. thereby robbing the engine of sufficient voltage to run or should the alt. be enough to keep it running???
