Re: Farmall Super C control valve for 3 point lift
Posted by Duane Rushlo on July 22, 2014 at 13:30:29 from (50.108.53.208):
In Reply to: Farmall Super C control valve for 3 point lift posted by mr.precision on July 22, 2014 at 12:52:56:
that hitch has a two way cylinder . it has presure
both ways. no way to float. there is a scren in the
resovey four bolt plate on left side . if you
changed fluid may have little air in lines will work
by usage.
