[/quote] Yes I have an aftermarket 3 point lift operated by a large horizontal rod running from the hydraulic pump lift arm to the rockshaft located in the back. Manuals are on the way, but I thought for sure there would be some type of control valve. Right now the only "flex" is where the vertical mount on the mower moves slightly from front to back.[/quote]
The control valve you are using now is part of the Touch Control and it's internal to the system and no way to change anything. If you mount a separate control valve, like the add on for a Fast Hitch, you then need a cylinder and hoses to operate the 3 point. Your 3 point is not made for an external cylinder, but with enough engineering and $$$ almost anything is possible.
The aftermarket 3 points for these are limited in range and lift capacity, whereas the Fast Hitch system or it's 3 point adaptors will lift the front of the tractor off the ground... I know, we had a Super C when I was a kid and I have a 240U now and they have a tremendous lift capability.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
