Re: Farmall M clutch issues
Posted by AG in IN on July 27, 2014 at 21:01:31 from (67.236.108.162):
In Reply to: Farmall M clutch issues posted by HillBillyRockStar on July 27, 2014 at 20:17:00:
Very late M, SM, SMTA, 400, and 450's flywheels should interchange.
Belly pump reservoir was changed to accomodate the larger clutch in the late M's and SM's. Part number should end in -EE to work with the larger clutch. This housing was also then used as a replacement part on the M's with the smaller clutch.
To my knowledge, the only pressure plate that will clear the belly pump in the late M/SM's is one made for a belly pump tractor. The pressure plate for a live pump SM will not clear the belly pump reservoir. My neighbor brought over a cob-job SM with a belly pump that instead of using the correct pressure plate someone took a grinder to the wrong one and also to the belly pump housing. Ruined a pressure plate and a pump reservoir.
AG
This post was edited by AG in IN at 21:08:48 07/27/14 2 times.
