Re: Re: Re: Re: 806 hydraulics, steering, brakes and TA prob.
Posted by Ace Schrunk on December 30, 2000 at 16:20:07 from (152.163.207.83):
In Reply to: Re: Re: Re: 806 hydraulics, steering, brakes and TA prob. posted by Lee K. on December 30, 2000 at 14:46:12:
Some good ideas but we need to correct something here the Power steering, TA, brake, lube and cooling pump is filtered buy the same filter as the Hyd pump in the rear end housing. there is a supply tube in the rear end that brings the oil to the filter from the filter to the TA housing there is a O-ring at the split between the TA Housing and rear end housing then a cross over tube to the front pump with a cup seal on it an o-ring in the pump a cross over tube to the hyd pump. if the hyd pump is working ok then filter and supply tube ok I would remove the MC Valve from the TA housing and clean it and check for ware you can check the pump when you have it off with oil in it buy puting your thump over the out port hole and turning the pump with your other hand if you can hold your thump on the hole when you turn the pump or if the pump turns hard buy hand with out thump over hole you will need a pump. when you have the MCV off check the little plastic check valve at the bottom rear of the MCV mount if it is bad no Power steering I hope this helps
Home
| Forums
Today's Featured Article -
Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
