560 D slow revving????
Posted by 44 massey on July 28, 2014 at 16:47:26 from (74.46.127.76):
Got the 560D out today going to take it to our local tractor show
Wednesday, started right up, usual smoke, hasn't been run since
last year!!! Run ok except when you pull throttle down its slow to
gain RPMs!! Noticed it a little last year but naturally forgot about it
till now!!! I cracked injectors lines one at a time just to check for
air, no air but definitely would drop that cylinder until tightened
back up!!! I changed fuel filters and cleaned sediment bowl and
bled system, didn't help!!! Tractor hasn't much run except for
parades and going to shows in last 10 yrs but always ran good!!!!
Put fresh Diesel in it too!! Any ideas?????
