The pump metering valve may be sticking. When at high idle does the engine want to under run low idle speed, or even die on deceleration? If so the valve is sticking. May also be the retainer ring inside the pump failing, plugging the return line check valve in the bottom of the fuel tank. Test by letting fuel leak out of the housing with the timing cover screws loose, if it revs OK then the pump needs serviced before the retainer pins shear off, locking the head/rotor and breaking the drive shaft.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
