Hi David, sounds like classic junk in the fuel tank that is common on the 74/84 series tractors BUT you said that engine does not loose RPM.
Next question does it have T/A (Hi/Lo lever on dash opposite throttle lever)? If so does it do it in T/A LO or only in T/A Hi? To test clutch drive tractor in 3rd Hi and apply brakes hard, it should drag the engine RPM down. If the engine is not dragged down and ground speed stalls then clutch or HI T/A is slipping. Try again with tractor in LO T/A, if engine is not dragged down and ground speed is stalled then clutch is slipping.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
