Re: Frozen key way
Posted by 300guy on July 29, 2014 at 20:31:44 from (76.85.170.101):
In Reply to: Frozen key way posted by Danh on July 28, 2014 at 06:25:24:
Here's another trick. Use a good center punch and put it at the end of the key in the shaft. Tap it down under the key and it should roll out also. Don't use too large of a punch,
