Frozen key way
Posted by Danh on July 28, 2014 at 06:25:24 from (70.192.73.191):
Working on our farmall h trying to replace the seals on the brake pedal shaft. On the clutch pedal side I can't get the key way loose to remove the pedeal. Any ideas on how to remove the key way that is frozen. Thanks
