Re: What other gas tanks will fit a 340?
Posted by farmallhal on July 30, 2014 at 19:54:08 from (76.2.172.244):
In Reply to: What other gas tanks will fit a 340? posted by blueridge on July 29, 2014 at 20:28:39:
I checked the IH on-line parts catalog and same tank assembly (part no. 369215R91) is used on both the gas and diesel 340 International and Farmall tractors. I could not locate the on-line parts catalog for a T340 Crawler so was unable to advise if the they use the same tank as the other 340 models. I do know the 240 fuel tank is different and is not suitable for a 340. The Farmall 404 and 240 used the same fuel tank and if the 504 is the follow-on model for the 340 it uses a different fuel tank so no match there. Good luck in finding a replacement tank as it sounds like you certainly need one but if it is the same as other 340's should be able to locate in a salvage yard, Hal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
