Re: Farmall B Starting
Posted by ken house on August 01, 2014 at 18:23:08 from (173.242.240.229):
In Reply to: Farmall B Starting posted by Rogerbayard67 on August 01, 2014 at 17:53:06:
motors will start easier rolling off, etc., than with starter.
maybe a timing problem.
does starter turn engine over rapidly? if not maybe an electric problem. maybe need to clean battery ground connections.
