Farmall B Starting
Posted by Rogerbayard67 on August 01, 2014 at 17:53:06 from (174.21.204.55):
Just got my dad"s Farmall B running
Will start with relatively short compression run (down hill coast) - Fires off after a couple of seconds after up to speed.
Runs fine after starting
Have been unable to successfully get it started via electric starter- engine turns over but have yet to sense even partial firing (new battery - 6 volt system)
or hand crank
tried starts with engine both hot and cold - no success
any suggestions
