Re: Farmall B Starting
Posted by David G on August 01, 2014 at 18:59:48 from (63.152.59.205):
In Reply to: Farmall B Starting posted by Rogerbayard67 on August 01, 2014 at 17:53:06:
Make sure you have a good blue spark that will jump 1/4 inch, and check your compression. Please check back after these tests.
The compression test should be done with throttle wide open and the engine warmed up.
