Re: Farmall B Starting
Posted by gene bender on August 01, 2014 at 19:10:09 from (67.55.226.121):
In Reply to: Farmall B Starting posted by Rogerbayard67 on August 01, 2014 at 17:53:06:
check to see if the rotor is lined up with the tower when it fires, mag or dist which do you have
