Re: Farmall B Starting
Posted by Notjustair on August 01, 2014 at 20:28:11 from (174.238.65.143):
In Reply to: Farmall B Starting posted by Rogerbayard67 on August 01, 2014 at 17:53:06:
That engine should take nothing to start with a crank. Even a cripple like me can get my A started in 1/2 of a turn. Clean the carb out spick and span and then check the timing. Check the compression as well - it could be too low to draw in the mixture. Something like seized rings.
