Re: IH 37 baler slip clutch
Posted by JRSutton on August 02, 2014 at 05:35:25 from (71.174.108.252):
In Reply to: IH 37 baler slip clutch posted by burnsg2003 on August 01, 2014 at 05:24:10:
I forget the spec too - it's very high - I believe the manual use a 10' breaker bar on it with 50 pound force - something like that. (to test the clutch of course - NOT on the bolts themselves)
I'm wondering though if you're sure it's the clutch itself that's slipping, or is it the overdrive ratchet part (for lack of knowing what the real word is)
Where the pto shaft comes in, that usually has block with two little spring loaded "dogs" (that you can't see) and they ride in a groove on the face of the clutch and in that is a series of ramped teeth (which you can see).
Sometimes those springs can give out - or the two dogs (steel dowel pins) can get worn, etc.
So if that happens, pto shaft can spin, but the rest of the clutch won't.
It can happen intermittently, and it can give the appearance of the clutch slipping if you don't look closely and/or don't think it through.
I've seen that situation happen more often than the actual clutch slipping.
