Re: IH 37 baler slip clutch
Posted by JRSutton on August 02, 2014 at 05:39:37 from (71.174.108.252):
In Reply to: Re: IH 37 baler slip clutch posted by JRSutton on August 02, 2014 at 05:35:25:
to be clear -
There's no way to spec a torque just for the bolts and get that slippage torque right.
You have to get the spec (estimating but probably way off) like a 10' pole with 50 pounds hanging on it.
if that makes the clutch slip - you have to tighten each bolt just a little bit - and do all of them an equal amount.
just keep repeating till it stops slipping.
