Re: clicking starter
Posted by Janicholson on August 03, 2014 at 15:11:50 from (199.17.2.114):
In Reply to: clicking starter posted by boomer22 on August 03, 2014 at 15:06:49:
Do not disconnect the cable when running. The battery is a voltage control element in the system. With no battery, it can put radical voltage in the system. If alternator, it can be 100 volts or more.
The solenoid is bad, the starter is good.
Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
