Re: clicking starter
Posted by CDN 400 on August 03, 2014 at 15:16:34 from (67.58.222.210):
In Reply to: clicking starter posted by boomer22 on August 03, 2014 at 15:06:49:
It sounds like your solenoid.Remove it from the starter and take the cap off it(the black piece)you will see that the large contact washer will have a burned spot in it as will the end of the one lug that makes contact with the washer.turn the washer over clean up real good and turn the lug to a new contact spot and reassemble.I have done this many times.Also put a volt meter on the starter lug when you hit the button to make sure you have full voltage if not your cables are junk.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
