Re: Farmall H won't run correctly.
Posted by JohnIH on December 31, 2000 at 06:07:47 from (208.169.39.21):
In Reply to: Farmall H won't run correctly. posted by Plow Man on December 30, 2000 at 21:52:11:
Anytime the running of any vehicle seems to change overnight I suspect a possible ignition problem such as a cracked distributor cap, water in the distributor cap, etc. Gas problems usually don't cause missing sounds as pronouced as ignition. Carburation problems usually come on gradualy with time, and it appears you were running that H enough to keep new gas through the cab. Might want to check it out.
Post A Followup
: Re: Re: Farmall H won't run correctly.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
