Re: farmall a on off switch question
Posted by Curt Cooke on August 05, 2014 at 08:43:00 from (64.186.50.66):
In Reply to: farmall a on off switch question posted by nick from md on August 04, 2014 at 23:48:18:
The original was either a cable pulled toward the operator to shut the tractor off. That cable was mounted to the steering column about knee high. Later the cable shut off was replaced with a grounding switch. The push/pull type switch was mounted vertically in a mounting hole that was attached to the throttle quadrant. Farmall A on/off switch was never in the box with the light switch and amp. gauge.
