Re: 756 310 German antifreeze in oil source
Posted by CDN 400 on August 05, 2014 at 13:06:50 from (66.103.45.36):
In Reply to: 756 310 German antifreeze in oil source posted by picassomcp on August 05, 2014 at 12:55:09:
The reason for your spun bearing is the antifreeze.Knock the sleeves out and you will find they will be pitted wear the o-ring seals the sleave.They might not be ate through but leaking past the o-rings.Those sleaves knock in and out very easy.Prepare your wallet germans are pricey to o/h and time you get all the machine work done as in head work getting your rods rebushed and resized it will be an expensive rebuild.If your oil cooler is bad it will fill the rad full of oil because you have more oil psi than cooling system psi.
This post was edited by CDN 400 at 13:10:18 08/05/14.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
