Re: 6 Volt glow plug vs. 12 Volt
Posted by mkirsch on August 06, 2014 at 10:33:12 from (72.45.143.81):
In Reply to: 6 Volt glow plug vs. 12 Volt posted by scott z on August 06, 2014 at 08:22:21:
Sorry, I am mistaken. They are wired in parallel. That is the only way they can be wired, as they only have one terminal.
Is it possible that the resistor, part #33 is no longer resisting?
This post was edited by mkirsch at 10:34:26 08/06/14.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
