6 Volt glow plug vs. 12 Volt
Posted by scott z on August 06, 2014 at 08:22:21 from (158.106.48.10):
I have a IH B275. I believe it has been upgraded to the 12 volt system. It has 1 - 12 volt battery opposed to 2 - 6 volts batteries that were standard for those tractors when they were new. My problem is I"m going through glow plugs and I don"t think things are working correctly electronically. I"ve been ordering part #710348R2 when I"ve been replacing glow plugs. Is that plug only rated for 6 volts? I have 12 volts going to the plugs per the amp meter. I"m starting to think I need different plugs that can handle 12 volts? Also, the tractor plugs are wire in paralell instead of in-series. Any information will help!
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
