Re: am i just asking too much?
Posted by Lmack on August 06, 2014 at 18:42:09 from (24.131.50.165):
In Reply to: am i just asking too much? posted by ericlb on August 06, 2014 at 13:55:49:
As Jim said, something blocking the fuel or just bad gasoline. If you had old gasoline in the tank it might run a little rough until you burn it out. Even if the bowl looks clean remove it and clean it out, flush the fuel line and drain the bowl on the carburetor. It doesn't take much to block up fuel flow and it will show up under heavy load.
