Hmm. Sorry I don't know the exact answers here. I'm just working off basic electrical principles and what I can observe, exactly how I would be doing it if the tractor were in my shop.
Looking at the original style glow plugs, it appears that there are TWO electrical connections, terminals, on them. One above the pink washer, and one below the pink washer.
If you have those wired up like the updated plugs, in parallel, it's no wonder you are burning plugs out. You need to wire them in series.
Looks like it should be, using the picture of the engine, and the wiring diagram from the parts book:
1. From the resistor to above the pink washer on #1
2. From below the pink washer on #1 to above the pink washer on #2.
3. From below the pink washer on #2 to above the pink washer on #3.
4. From below the pink washer on #3 to above the pink washer on #4.
5. From below the pink washer on #4 to the engine block.
Someone must have installed the updated 12V glow plugs at one time, and you've replaced them with the OEM plugs.
OEM plugs are rated for .9V (9/10 Volt per the picture in the other thread). If you pump 12V through them... PIFF!
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
