Posted by SW EM on August 07, 2014 at 20:21:18 from (166.181.80.14):
My dang 400 has sat at the Iowa fairgrounds since Tuesday, and today it wouldn't start! It had been rained on Wednesday and Thursday, so maybe that's why it won't start. I had the exhaust covered too. I believe it is getting fuel because it drips from the carb after I try to start it. As the motor is cranking a fine white mist seems to come from the muffler (unburnt fuel?).I've checked the firing order, checked for moisture in the distributor cap and plug wires, and I ran a dollar bill through the points. My battery is one crank away from dead....
Could it just be moisture somewhere in the electrical system? Condenser? It has a 12 volt conversion kit. Would water on the resistor be causing a problem? I have to have it running by around 9 AM for FFA judging
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
