Re: international574 not charging
Posted by Owen Aaland on August 09, 2014 at 17:45:23 from (216.47.34.49):
In Reply to: international574 not charging posted by jim23377 on August 09, 2014 at 15:13:05:
Early 574s use a 10DN alternator with external regulator. They use three wires on the alternator. A hot lead from the ammeter gauge, a ground wire, and a wire from the regulator on the F terminal.
Later ones use a 10SI alternator with the internal regulator. the gasoline models use a diode between the key switch and the #1 terminal. Diesel models use a resistor instead of the diode. The #2 terminal has a wire from the battery cable post on the starter. Thee wire connected to the output stud on the alternator comes from the ammeter gauge.
They all use a gauge rather than a light for charge indicator.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
