Re: am i just asking too much?
Posted by NNP on August 10, 2014 at 05:46:19 from (66.66.112.196):
In Reply to: am i just asking too much? posted by ericlb on August 06, 2014 at 13:55:49:
check ignition for a weak spark first.
A spark checker taped on so it doesn't fall off or a timing light
lashed to the hood will let you see what the spark is doing when it
fails on you.
ignore the mower for now, a good running engine when overloaded will slow smoothly until it quits or breaks.
Remove the load and it should recover immediately.
Lots of good advice on the gas flow issue.
(those flat rust flakes floating around in the tank have randomly bit me a few times.)
Don't forget, the opposite could be true also.
When mowing with my Super H, a random 'running ragged' issue
is sometimes small debris holding the float needle open.
Clues are, pulling the choke rod a little will make it worse.
And since it has happened before, when I see the faint black smoke coming out the exhaust, I know what it is.....
