Posted by tim11612 on August 11, 2014 at 14:29:13 from (32.220.43.22):
In Reply to: Re: Alternator for C113 posted by PretendFarmer on August 11, 2014 at 09:51:44:
what makes you think it had weak spark while pulling? it looked good to me,it didn't have the power I thought it should have,you have the good head on it,3 1/8 dome piston.timming may be off alittle and makes it run hot,loose a little power also.youll also loose power if the valves aren't adjusted correctly on those c engines,i know you just put on the good head..also the drawbar needs to be reworked and rear tires need to be the same size.
