Re: Farmall only runs with choke closed
Posted by scott mcintosh on August 11, 2014 at 16:37:59 from (216.180.204.136):
In Reply to: Farmall only runs with choke closed posted by R Weld on August 11, 2014 at 16:23:36:
Check your fuel flow at carb.If that is good check screen in carb.Don't touch governor that is not your problem.Check these first and post back.Scott
