Delco 10si hookup help.
Posted by PretendFarmer on August 12, 2014 at 11:06:50 from (66.87.124.193):
I'm a little confused here. I hooked up the batt terminal straight to the positive side of the battery. Then I hooked the number one(r)to switched ignition power. Finally I hooked up the number 2(f)terminal to the batt lug.
When I ran the tractor it seemed as if the alternator was putting quite a load on the motor. Also when I tempted to shut the tractor off, it would not shut off I had to shut the gas off. Do I need to put a diode between number 1 terminal and the switched power to prevent backfeed? If so what's the most ideal one?
