Re: Delco 10si hookup help.
Posted by Bob M on August 12, 2014 at 11:48:31 from (67.240.162.4):
In Reply to: Delco 10si hookup help. posted by PretendFarmer on August 12, 2014 at 11:06:50:
My preference is to stick a #168 or equivalent side marker/instrument panel lamp between the ign switch and the #1 terminal.
Advantage is it will work same as the alternator warning lamp in your car's dash, lighting up if the alternator fails, the fan belt breaks, etc.
