Re: H idle
Posted by gene bender on August 13, 2014 at 07:47:24 from (67.55.226.121):
In Reply to: H idle posted by CPACy on August 13, 2014 at 07:15:37:
Your problem could be in the dist when the bushings get bad engine wont idle very good as the fire is intermitten. You can check that with a tming lite going from wire to another and watching for constant flashes also have you checked the tappets.
