Posted by CPACy on August 13, 2014 at 07:15:37 from (216.81.237.137):
New to me H hadn't run in several years, but previous owner fiddled with it enough to get it to start but was rough runner. I took carb off and cleaned it up after reading instructions on the forum. I also used the settings that everyone posts on here.
I can get it to run and it purrs, but I don't think it is "right". It won't start when I'm cranking but fires up after letting go of the starter. It stumbles for a second and then starts to run fine.
Also, the lowest idle speed that it will keep running is when the throttle lever is 1/2 open. The engine sounds like it is turning RPMs that normally would be at low idle.
Are these just carb adjustments that need to be made to fix this? If so, what are they? Is there something else?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
