Re: H idle
Posted by Bob M on August 13, 2014 at 08:22:10 from (67.240.162.4):
In Reply to: H idle posted by CPACy on August 13, 2014 at 07:15:37:
As Rusty suggests the starting issue is probably an incorrectly wired 12 volt conversion. Or if your H is still 6 volt its got a weak coil or worn/incorrectly set points.
The idle problem is the carb idle stop screw set too low AND the governor-to-carb linkage out of adjustment.
