Re: H idle
Posted by Charlie M on August 13, 2014 at 11:18:39 from (24.39.229.234):
In Reply to: H idle posted by CPACy on August 13, 2014 at 07:15:37:
Concerning your idle speed, there are a couple of places to look. One is on the carb and it is a screw that adjusts to physically stop the throttle. It prevents the carb from being totally closed with the throttle. If that doesn't change the idle speed then look inside the governor. There are high and low speed screws in there you can adjust. You also want to make sure the linkage isn't binding somewhere.
