Re: Farmall M Stops moving/PTO while mowing
Posted by Trevor H on August 14, 2014 at 03:56:05 from (166.147.123.39):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
I plan on keeping this tractor for life.... Would you guys recommend splitting the tractor to service the clutch/ flywheel
Or can I remove the flywheel if the belly pump is removed?
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
