Re: Farmall M Stops moving/PTO while mowing
Posted by rustyfarmall on August 14, 2014 at 06:40:37 from (208.126.186.41):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 14, 2014 at 03:56:05:
The clutch can be serviced without splitting the tractor, but the belly pump must be dropped. The pressure plate and clutch disc can then be removed, but the flywheel WILL NOT fit through that opening. That flywheel is HEAVY. A normal guy would not be able to remove it from below, even if it did fit.
