Re: H idle
Posted by CPACy on August 14, 2014 at 06:04:46 from (216.81.237.137):
In Reply to: H idle posted by Billy Staples on August 13, 2014 at 07:15:37:
Thanks to all for the places to start. Once I get back out to the farm, I'll see what I can do.
As for the carb adjustments, i searched "h carb" and found something similar in a couple places.
First off, this was posted by FBH44 and I am in no way claiming that it is my own.
As it was on here a couple times and no one wrote back in to say that it is wrong, I took it as it was a correct way to adjust.
Posted: Sat May 10, 2014 8:13 am Post subject: Re: H dies when throttling up
You might not need this, but it might help. My "H" carb adjusting procedure;
Make sure the float isn’t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so the float doesn’t rub or touch. Pretty important.
Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber.
Initial settings are as follows to get it started;
Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. [This screw adjusts fuel.]
Idle air-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. [This screw adjusts air.]
Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages in the slot. [This screw adjusts RPM’s.]
Final settings are determined as follows;
Get the engine warmed up, and idling.
Turn OUT the idle air-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.)
Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine is set at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.)
Should rev up smoothly and evenly.
Too Lean = stumble, sputter, damaged melted plugs.
Correct = tan plugs.
Too Rich = back smoke, black sooty plugs.
