Re: Farmall M Stops moving/PTO while mowing
Posted by kevinj54 on August 14, 2014 at 12:48:05 from (162.17.149.81):
In Reply to: Farmall M Stops moving/PTO while mowing posted by John M on August 14, 2014 at 12:42:14:
That is why I asked if the pedal was back all the way. (no answer)
When worn out the throwout binds up from a worn clutch and the pedal will not return. (causing lack of pressure on the disc)
Some pics of the linkage would help too. The rod may shortened all the way at this point.
Also his comment about the PTO makes no sense as it drives off the counter-shaft.
